MasterChief
hi i have built a Hquad and it is very unstable and it is drifting towards one side
i have tested it with a v2.5 firmware and configured everything properly but it drifts at one side and i have adjusted the trim in the controller and the pots in the kkmulticopter board but still drifts when it hovers
my config is as follows:
end to end length of the frame is 19cms
landing gear length is 3.5cm
propellers: 3 blade 5x3 gws
motor : dys 1600kv
esc: dys 10A
battery:7.4v 1200mah
rx/tx: 6 channel 2.4GHz
kkmulticopter v2.5 firmware
weight:400gms
is there any other factors im overlooking ? and i am unable to configure it with v4.7
and i am also gonna build a new one with 25x25 cms size and i need to know which propeller and battery to use i have 4 emax cf2822 motors and 4x40A mystery esc
it is mainly for FPV and i need a easily configurable flight board and which is better ? MultiWii or Ardupilot ?
thanks in advance
motor : dys 1600kv
esc: dys 10A
weight:400gms
thanks in advance
