H-Quad Knuckle with Naza M Lite and GoPro
bucket183
I am looking at building the H-Quad with the Naza M Lite and GoPro as a FPV Training platform for my Tarot FY680 with Naza M V2.
Do you think the H-Quad will handle the Naza and gopro??
Has anyone put the Naza on the H-Quad, how did it go??
eXsoR
Does any one know if this is possible. A Rotor Bone H-Quad with the Naza-M Lite with GPS??
Mustang7302
The Naza will fly on a Knuckle frame. The Naza is a very docile controller, limits the envelope of performance dramatically versus a KK2, which is very smooth and easy to learn on; only down side is that it wont be very fun to throw about.
Pair the Knuckle frame with the following power plant, and you're in the air for at least 10 minutes with plenty of lift for a go pro and FPV hardware.
Motors: NTM Prop Drive 28-26 1350K
Motor Hardware: NTM Prop Drive 28 Series Accessory Pack
Propellers: 9x4.7" CW & CCW Pairs
ESCs: Afro ESC 20Amp (SimonK Firmware)
Battery: Turnigy 2650mAh 3S 20C Lipo Pack
Remove the red wire from the ESC's servo connector when plugging into the Naza controller; it doesn't need the 5V power as it gets its power from the auxiliary module with the status LED and USB port.
