Hi,
maiden yesterday the ME 163 Komet from Hacker. An amazing little foamie. It is Increase easy to start and flys amazing. Really stable and agile without being to twitchy.
With 3s is allready pretty fast and with an updated powerpack and 4s can reach 200km/h
The space por battery is enormous flexible and you can use 2s to 3s from 500 mah to 1800 mah without CG problems.
Now some pictures and specs.
Two versions available.
I have the red one:
This are the Specs:
Servos motor and ESC´s are installed. Only the Vertical stabiliser has to be glued in. The receiver fits perfect at the bottom of the fusselage and the antenas can be passed throug a opening in the bottom of the fuselage:
ALl this batteries fits perfect. I balanced the CG for each of them and make marks inside to now where tho place them at the field.
I can highly recommend this tinny warbird.
And now some impressions from the maiden. Sorry for bad quality but the Wintertime has started and the light conditions are really bad.
I have the red one:
This are the Specs:
