I am working on developing a needle saw (basically a tattoo machine). Here is a quick video of my prototype.
Any suggestions or comments?
Ben
The cuts are pretty clean. Yes it is a conventional or rotary tattoo gun with a 6mm stroke on one and a 4mm stroke on the other. I will be doing a full build of the machine soon and I will record it. I am also working on a nice 3D printed version. All plans from me will be free.
I owe you a debt of gratitude for your posts here David. They set off a storm of ideas in my head for things like this. So thank you!
I built it because I am currently CNC challenged. I am building a CNC platform shortly but work and family are extending the time to build it further than I had expected. This took me a couple hours to build and I was cutting out my robot platforms that are inspired by the FliteTest foam core planes with it.
Thanks, Ben. Glad I could help in some way
This really looks good. There's been talk of developing a hand-held needle cutter in a couple on my threads but, to my knowledge, you are the first to demo a practical unit. I've looked at the prison tatoo guns before of course but never really thought, in a light-weight unit, they'd have the power to pierce/cut DTFB... kind of a "worst case" foam, with the paper on both sides. Yours seems to do so very cleanly and quickly... that's some serious power and RPMs you have there. I'm really looking forward to seeing how you selected components and put it all together.
Good work! -- David
Any indication of what "downward pressure" is needed to obtain a correct cut with a needle cutter on DTFB ? Wondering if "laser engraver" like architecture wouldn't be sufficient for that use case (as opposed to full CNC)
I would be very interested in how you built that
That is sweet. Have you tried any freehand with it, say on a round shaped rudder? Or strictly straight line cuts.
If I understand your question about using the needle cutter on a "laser engraver"... if you do not have a Z-axis implemented that will lift the cutter out of the material, then you will have to have some way to stop the cutter's rotation at the top of stroke, when the needle is clear of the material being cut, to move to the next cut. I'm not yet sure of how Ben's cutter is constructed but it does appear to me that every time he sets the cutter down on the table the needle may be fully retracted... so he may already have addressed that problem for you. -- David
Actually, the question was not about lifting/lowering the z-axis, but how "strong/rigid" the 3 axes actuators need to be to control the needle saw. I supposed that the forces were low enough to use lightweight 3 axes rails/motors rather than full strength ones.
Very nice, Ben. I've been anxious to hear more about your hand-held cutter. Are you, by chance, planning to release the STL files for those of us who are OnShape-challenged? -- David
Of course! You should be able to right click the stl tabs at the bottom of the Onshape document to download. If not I'll correct that in the morning.
