Lol sound like every time I went out to fly 😖At first it was a hard left hand bank, second was nose dive, third and in have been nose dive with a bank right
Yea its something that has happened to me a few times. My issue was not enough power in the throttle and/or the toss. You said you have gone through a handful of planes with no flight yet?
What plane do you currently have?
Do you have any vids of the offending launches?
Gonna need some details to help you diagnose the issue my friend. Maybe we can talk you through the problem so you can get some quality airtime. Sound fair?
I have built several planes and I can't figure out how to hand launch. Can anyone help please?
Yeah I'm a newbie too. My first plane wouldn't fly, I just repeatedly threw it and it repeatedly crashed. Turns out it needs to be trimmed correctly and CG adjusted. (I will when I get around to it.)
My next two planes just fly right out of my hand, to the point where I'm getting lazy with the toss - I wind up as often as not just tossing even slightly downward and it still flies awesome.
For me with the plane balanced correctly and trimmed correctly it'll take off for you just fine. (If it's a good flyable plane to begin with.) I've been setting my throttle at around 65% and with a bit of up elevator. Hope this helps.
FT CorsairNavyFlier
Without more details of exactly which FT speed build kit and its weight my guess is your plane is heavy for its size.
A 'C' power pack and a 2200 mAh 3s battery is intended for larger planes (50" span?) and thus are heavy for something at the 30" span.
Hand launching such a combination would be difficult as it would not be a flying speed as it left your hand and would have to rely on its excess thrust to get to flying speed before it hit the ground. Sounds easy but too much throttle and the motor torque will cause it to roll over and crash, too little power and it will never get to flying speed and crash.
My suggestion is you need to loose a whole chunk of weight (smaller motor, prop & battery) so it will be able to fly at a speed you can sensibly achieve with a 'controlled' hand launch.
I'm still afraid of launching too! But I have no reason to - a good-flying plane will take off just fine.Which planes are you currently flying? I have a FT Bloody Barron built, but am apprehensive to toss it for fear of the crash.
FT mini corsair or master series corsair?FT Corsair
That's a good question. The warplanes run hotter - they need more airspeed and need to be trimmed with more precision. Somebody please verify the Bloody Barron will be more forgiving.FT mini corsair or master series corsair?
I've made both. The Master series crashed. I haven't tried flying the miniFT mini corsair or master series corsair?
