So a while ago I decided to try and make some plans for a swappable, and I went with the Heinkel HE 51. Why an HE 51? Idunno, seemed like a good idea at the time.
This is the first finished version, feel free to download and build the plans. If you encounter a problem building or flying it, please, let me know so I can improve the design.
Update: 7/13/2014
I just finished the plane today! I'll get working on the instructions, in the mean time, have some pretty pictures!
Front
Cockpit
Isometric
Assuming you have everything all cut out and you've made a few Flite Test designs, here's the instructions.
Upper wing
Fuselage
Final assembly
Update 1: Added a bunch of spars, the lower wing, slots for the fuselage on the horizontal stab, and the bottom cowlingy thing.
Update 2: Added turtledeck, servo arm slots, adjusted wing saddles, labeled folds, added posterboard stuff, finished first design.
Update 3: Added a slot for the servo leads on the mid wing, turtledeck, and fuselage ceiling.
Update 4: Flipped the left wing. WHOOPS!
Update 5: Adjusted the mid wing's saddle slots.
Update 6: Removed power pod slots, adjusted mid wing's saddle slots AGAIN, corrected width of turtledeck braces.
Update 7: Expanded the width of the turtledeck cover to adjust for the braces.
Update 8: Expanded the exhaust, and the cooling intake, added a slot for the vertical stabilizer on the top of the fuselage, removed the extra score on the intake, and shortened the tail, it was half an inch longer than it should've been due to a mathematical error.
Update 9: Removed unused spacers, corrected size of the lower cowling.
![HE 51 Board1.png HE 51 Board1.png](https://ftforumx2.s3.amazonaws.com/2014/07/73297_62d805c5956cda98c812d7331d9f570a_thumb.jpg)
![HE 51 Board2.png HE 51 Board2.png](https://ftforumx2.s3.amazonaws.com/2014/07/73298_2e6155849720a9fecc89237ac8e5cd79_thumb.jpg)
![HE 51 Board3.png HE 51 Board3.png](https://ftforumx2.s3.amazonaws.com/2014/07/73380_5a87e14715eb799ed2655c41aea798f8_thumb.jpg)
Update: 7/13/2014
Front
![IMG_20140713_204754.jpg IMG_20140713_204754.jpg](https://ftforumx2.s3.amazonaws.com/2014/07/73254_f7d761f5a2ebce5842cd0c957db23e32_thumb.jpg)
Cockpit
![IMG_20140713_204718.jpg IMG_20140713_204718.jpg](https://ftforumx2.s3.amazonaws.com/2014/07/73256_cf3fc9d6c7b4aafad8cb0ac2ae4e5d3e_thumb.jpg)
Isometric
![IMG_20140713_204650.jpg IMG_20140713_204650.jpg](https://ftforumx2.s3.amazonaws.com/2014/07/73258_d38a45bd5b012558e8f518f2c6f3c783_thumb.jpg)
Upper wing
Fuselage
Final assembly
