Hello
I was going to wait until I’d finished before I posted anything as still not sure whether it will fly but have hit a problem.
I’ve been building this Hellcat from rc old guys site.
https://www.foamflying.com/rc-prop-planes.html
Here are the plans and tips from the man himself.
https://www.foamflying.com/uploads/1/4/9/0/14901388/old_guy_rc_hellcat.pdf
https://www.foamflying.com/hellcat-build---curl-and-form.html
The servos are fitted upside down underneath the fuselage stuck to the bottom of the wing.
It’s the other end that’s the problem
When fitting the control rods the one for the rudder presumably comes straight out of the bottom hole at the rear of the fuselage (see upside down photo below where pen top is pointing!) .
I assume for the elevator rod you poke an ( ugly)hole through the fuselage somewhere near the rear?
Had an idea though,probably daft but here goes
What about gluing it’s popsicle stick / control horn to the barbecue stick instead of the elevator ,moving the barbecue stick a little way back from it’s present position then the elevator rod could come through the bottom hole at the rear of the fuselage as well,thus avoiding making an ugly hole in the fuselage at the side?
Maybe crazy and there’s probably some common sense reason it won’t work.
any thoughts anyone?
Thanks
Thanks
