Hello and request for advice
Frankschtaldt
Firstly, G'day from the land of Aus (country NSW, half way between Sydney and Melbourne)
I'm looking for a bit of advice from some people experienced with things my local club isn't...
Firstly, a bit of a story about myself, just to put the questions that are to follow into a bit of context.
I've been obsessed with RC plains for as long as I can remember, about 20 years or so ago I finally got enough money together to buy everything I needed to fly. A lovely fellow from the local club donated a fair bit of time to help me get my model airborn (which honestly took me longer than it should have considering how keen I was).
Anyway, flight day finally came after a few months of slowly putting together my trainer.
My helper took off, adjusted thrims, got some altitude and said "are you ready?", I said "where is it? I can't see it"
That was one of the first clues I had that my eyes were failing on me.
Turn out I have two fairly rare eye conditions that work together to ensure that i will never see the world clearly. I can see well enough to pass my vision test for my drivers licence but that's nowhere near enough to see a small trainer at altitude, not clearly anyway.
So, fast forward 20 odd years and my obsession has never really gone away. My local club recently had an anniversary show (that was all but rained out) that I took my nephew too, I was more interested than him! So when I got home I started hunting for small cheap RC plains thinking, if I could find something small enough to fly around my back yard my eyesight wouldn't be a factor, plus I want to keep it cheap in case it turns out that even that is no good so I don't waste too much money.
So, after a bit of reading, I think I've settled on Nerdnics Manic Micro Tigermonth as my first build. My main concern, and first request for advice is the repeated comments from my fellow Aussies that our foam board is too damn heavy, not helpful if you want to keep something light and slow.
My plan to counter this problem is four fold:
1) Build a 3 channel version (just don't put the ailerons in, and move the elevator and rudder servos forward to counter the CofG issue the heavy foam causes) thus saving a servos worth of weight
2) Remove the inside paper from the fuselage sides (a model this small shouldn't suffer too much from the lost strength)
3) Use the lighter battery option
4) Bigger wings! I've printed off a modified version of Nerdnics plans with 10% wider wing span and no aileron cut out.
I would like to know if people experience with this model and/or our heavy paper think that this would work?
Is it enough, is it too much? Any other suggestions? Am I just kidding myself?
If this model works I'll just save up and buy a box of the Flite Test foamboard. Even with the insane freight it's still cheaper than the local stuff and it's the correct weight!
The other request for advice: being an Aussie, I'm used to paying way too much for everything (we call it the Australia tax). I've found a radio that's available from the Australian Hobby King but seems too cheap to be believable, it even comes with a really light (6.4g) receiver. It's a Turnigy TGY-i6. I've asked my local club if it's any good and they have no experience with it. So, has anyone here used this? Will I regret buying it? I don't care if it's low rent or feels cheap. I just care if it does what it's supposed to do and isn't going to frustrate me. If this all works out I can upgrade to a nice set later on, I just want to keep my costs low for now but I don't want to sabotage myself by doing so.
Thanks in advance!!
nerdnic
nerdnic.com
Hi there! I think you made a great choice for a first plane :)
To keep weight down I would remove any paper you can. Some of flown my tiger moth with no paper at all and it worked fine. You will probably need the the larger battery to get the right CG. Your tail is going to be heavier from the foam so that means you need even more weight up front. Getting the CG right is critical on these little planes. I would also go with a slightly larger motor as the 5g I use may not produce enough thrust. Maybe a 10g 1306 type motor might work better.
Keep me posted on your build and good luck!
Frankschtaldt
Hi Nic, Thanks for the advice. I'm a little nervous about making it with no paper, though a sheet of foam board doesn't cost that much so I guess I can try and just remake if I'm not happy.
Another noob question though, if I do up size the motor should I also up size the prop? Keeping in mind I want to keep it as slow as possible.
I've been using the i6 for about a year and have no problems so far. I got the first one in a 260mm Quad kit I bought last summer. Really good range and easy to program. Best buck for the money in my book. I've modded it with 10ch firmware (with timer) and it still works great. Since then I've got me another one, the original Flysky version. Modded that one too. For motor I would suggest the slightly bigger https://hobbyking.com/en_us/turnigy-1811-brushless-outrunner-2900kv.html
Works great with a 5x4 Kingkong quad prop. But Nic advice is probably better. :)
As for close flying you can also build the FT Mini Scout, can run of a 1806 quad motor and a 6x3/6x4 prop.
Welcome to the forums, just keep asking, there will always be someone that knows something about it.
Hai-Lee
Old and Bold RC PILOT
If you want to keep it slow fit a SF, (Slow Fly), prop. Another advantage is less "P" factor and almost instant thrust at very slow speed. The SF props work best, (Most efficient), at slow speeds. It also allows your throttle setting to be a little less critical if you are not very experienced at RC flight.
At smaller sizes an appropriate Quad prop can be used as a SF replacement.
Removing from the paper from heavy FB is simple if you know how. There are two simple but rather elaborate techniques. First one needs you to apply white glue or similar on the paper to be removed and when it is thoroughly dry just lift the edge of the paper and peel it off. The glue binds the paper together and it comes off in one piece. The second method is to lift the corner of the paper and drag the paper down over the edge of a hot iron. In this method the bond between the paper and the foam is weakened by the heat but it must be done quickly allowing the paper being pulled to create the speed at which it is done. A little practice would be good before doing it on the parts you require.
Welcome to the forums from a fellow Aussie!
Frankschtaldt
Hi m00ndancer and Hai-Lee.
Thank you both for your helpful advice also.
You've all given me confidence I'm heading down the right path with a couple of adjustments (as suggested) I should be able to have something workable.
I'm currently in the middle of renovations so won't be able to start work on anything for a few weeks but I might try to put in an order with Hobby King this week so I'm not delayed waiting for a delivery.
slipshift
Frankschtaldt, welcome to the group. I can relate to failing vision, I'm 71 Y/O and am just learning to fly. My instructor would fly so high all I could see was a grey smear. Overcontrolling, as noobys do, caused the plane to fall from the sky. My flights were only 3-5 seconds before my instructor took over. Now I'm trying it on my own, flying only 50' high. Still crashing but getting 10-15 second flights in. Each one gets a little longer and someday I hope to try a landing. :eek:
Jim
Frankschtaldt
Thanks for the encouragement, Jim.
My plan is to do something similar. As far as I'm aware it illegal to fly RC planes in public places in Australia unless it's as part of an RC club so I figured if I can slowly teach myself with something small and tough iny back yard I'll eventually be able to go and fly at the club when I no longer need someone to back me up so can just keep my model within my own limited sight range.
Hai-Lee
Just one little recommendation if it is not too late. Try to get the iA6 2A version as it has 2 antennas and when installed properly the occurrence or polarisation losses and signal fade are eliminated, In short the antennas do not need to be both oriented in the same attitude to get maximum range.
Hai-Lee
I hope it does because I had the HK version of the single antenna model and polarisation issues caused me to crash so often that I withdrew it from use.
Frankschtaldt
It says "Spread Spectrum Mode: AFHDS 2A and AFHDS" in the description for the Rx and the picture is very small but it looks like it has two aerials.
Does that mean anything to you?
Hai-Lee
Yes it appears the better unit also use the 2A setting only or the issues I had earlier will occur for you also.
There are three(four if you count the 10ch one) really good RX at the moment in the Flysky range and a smaller one with no telemetry and only one aerial:
All of them uses the new and improved AFHDS 2A protocol.
FS-iA6 6 channel with no opitions for sensors if not modded (for FT minis but have to be modded for LiPo voltage)
FS-iA6B 6 channel PWM 8 ch PPM and 10?ch I-Bus (My favorite for bigger planes, not FT mini)
FS-iA6X 6ch(PWM), 8ch(PPM), 18ch(i-BUS), S-bus and made to work with a Flight Controller (Naze32 for example)
FS-iA10 10ch(PWM) ?ch(PPM), ?ch(I-bus)
FS-A8S PPM 8CH, i-BUS 18CH, Sbus and single antenna. Made to work with a Flight Controller (Naze32 for example)
Frankschtaldt
Hey m00ndancer, thanks for the info.
I've just placed my order and this is the Rx that is coming with it: "FS-iA6 6 channel with no opitions for sensors if not modded (for FT minis but have to be modded for LiPo voltage)"
I'm now a bit concerned about this part of your description: "but have to be modded for LiPo voltage"
You are right, the Rx has 4.0-6.5V written on it which means 1S is to weak and 2S will be too strong (the model will be 2S).
I'm going to have to mod it, do you know how? Or can you point me to a how to?
Hai-Lee
I am in Aus and the rules are under 500 Gram AUW there are no real restrictions, (basically considered as a toy.
You should not fly within 50 metres of a building or similar structure. You should NEVER exceed 400 feet in altitude.
Finally if you wish to fly larger aircraft you should had insurance and fly at an approved field.
Do not fly using FPV and googles unless you have a person to "Spot" for you and you may never use the video or pics taken from a Drone or RC aircraft, (for financial gain), without a permit of licence to undertake such photography.
Approved field means anywhere you have the permission of the owner to fly unless there are air traffic considerations to consider.
Drones are a different beast with a few extra rules! Manly because they can hover outside of peoples windows and thereby participate in BAD THINGS!
As for the battery issue just remember a BEC or even a cheap ESC has a 5 volt regulator and can allow a Lipo replace a dry cell installation if required.
Frankschtaldt
Hai-Lee, you are a wealth of useful information!
I had no idea what a BEC was but you are correct, my ESC has an inbuilt 5V BEC, so I should be good!
Also, great to hear about the 500g AUW limit, as at least to begin with that's all I'll be flying (target AUW for the Tiger Month is 80g).
I live very close to a football field so I should be able to use that as long as the wind is soft enough and no one is using it.
If I ever progress pass these tiny models I plan to go join my local club anyway.
Thanks again mate!
Hai-Lee
Just one additional bit of info. Small planes struggle in any sort of wind. Get the verbal nod from the football club and build amd fly models around the 500 gram as they are so much easier to fly.
My first plane this time up was a Champ and whilst I could fly it any wind made it a real battle. I built a few others with limited success. Finally I built an original version of the FT Tiny Trainer and suddenly the penny dropped. That was about a year ago and now I build and fly anything i have a fancy for including my own designs and even experimental aircraft.
really around a metre wingspan is easier to fly.
