Hello and request for advice
Frankschtaldt
So, I just learned something very interesting.
I went for a ride today and by coincidence *cough* I rode past the local club. I saw some people where so decided to drop in to have a look.
As luck would have it, the gentleman that helped me years ago was there.
We had a bit of a chat during which I mentioned my sight, he said "You just need to work out which colours you can see. I use red and white", pointing to his model. "You probably don't want something camouflaged like this"... we were all standing around a model of a twin engined bomber that was about to go for its maiden flight, it had a black underbelly and a dark camouflage pattern on top.
So, I watched a few birds go up and couldn't really see squat.
Anyway, eventually the bomber goes up and low and behold I can see it quite clearly. Well, still out of focus but I had no issues telling which wing was up or down, which way it was facing or anything, no matter how high they took it.
The comment was something along the lines of "I think you've found your colours".
I probably want to see a few more models in the sky before I do anything silly (by that I mean spend more money) but I think I just need to keep my models dark.
Hey m00ndancer, thanks for the info.
I've just placed my order and this is the Rx that is coming with it: "FS-iA6 6 channel with no options for sensors if not modded (for FT minis but have to be modded for LiPo voltage)"
I'm now a bit concerned about this part of your description: "but have to be modded for LiPo voltage"
You are right, the Rx has 4.0-6.5V written on it which means 1S is to weak and 2S will be too strong (the model will be 2S).
I'm going to have to mod it, do you know how? Or can you point me to a how to?
No worries really.
(This might be redundant info, I'm sorry if that's the case, I'm not trying to patronize you.)
I was in a hurry and might not have explained it properly.
The TX can receive telemetry from the RX, meaning that you can for instance monitor your flight LiPo thru the balance port. So you don't drain the LiPo and damage it. The 4.0-6.5V on the RX is just the range of voltage the RX can accept from the ESC/BEC (Electronic Speed Controller/Battery Eliminator Circuit), so no worries there.
On to the long explanation on how to not destroy LiPo.
The upside of the iA6 is that it's light, the down side is that it only sends the input Voltage from the ESC/BEC not from the Voltage LiPo. There are a few things you can do to alleviate that.
  • Test things out with an egg-timer, set it on 4 minutes and land when the time is up. Check the voltage on the LiPo.
  • Get a LiPo alarm, put that on the balance port on the LiPo and set the alarm to 3.7V to be on the safe side. Land when the alarm goes off.
  • Modify the RX and send the telemetry info to the TX, with an alarm set on the TX. But the you have to reprogram the TX with new firmware you get the correct alarms above 2S Lipos. (The stock firmware only goes up to 10V)
My first plane (Wltoys F949) I flew with a small kitchen timer (no timer on the radio at that time). (the i6 can use the old flysky protocol as well)
My second plane was my first outdoor plane, a FT Spitfire. I've been flying it with a LiPo-alarm since I built it last year, but now I've changed the RX to a iA6B with a CVT-01 Voltage sensor attached to it. It sends the voltage reading to my TX (modded for correct Voltage above 2S LiPos, easy to do)
All the other FT planes after that have the same configuration except the Ft Scout. That plane I fly with a timer (haven't modded the RX yet)
I'm waiting for my first iA6X to connect to my Naze32, that combo is going into my next project.
So you really need a few things more than just the Tx/Rx to get the most out of the Flysky family at a low price.
Banggood.com is a great source for those things. Here is a list of things to get:
  • Programming cable to upgrade the Firmware on the TX
  • Lipo Alarms (as small as possible for the minis)
Now you may ask why I didn't go the Spectrum, Taranis, Graupner route?
Cost, I have a limited budget and did my homework (I basically vacuumed the RC groups forums for info.)
The TX-sensor combo is a third of the cost of any other solution on the market. The radio is half the cost of any other big brand.
Sure there is limited support from Flysky, but replacement parts do exists. The quality is good, considering the price you pay. The modding scene, people have modded this little radio to do really amazing things.
My modded Turnigy i6 has 10 ch, supports PWM, PMM, I-Bus and S-Bus. Supports 2-6S battery telemetry and a bunch of other sensors. A rudimentary timer is there as well. Now I have to get my butt off the couch and mod the Flysky i6 as well, it's on an older version of the 10ch firmware. (But I don't have the time at the moment to re-program all the models)
If you need any assistance, just send me a PM and we can talk thru Skype if you like. (Apologies for the English as well, not my native language, but I hope I get my point across)
Frankschtaldt
For the Tiger Moth I'm not too concerned about that level of detail so I'll probably just keep it simple and just time flights with my phone.
The first challenge will be just to learn to fly.
However, I am a bit of a nerd and I love details so I can see myself getting right into modding electronics like you have.
Should be good for giving me something to do while I save up for the next model too :)
Also, for the moment it's pretty safe to assume I know nothing.
My knowledge about aerodynamics and the physics behind flight is fairly good but the equipment has changed so much I prtty much know nothing about modern hardware.
Userofmuchtape&glue
Hello Frankschtaldt, Good to meet a fellow aussie!
I use the TGY i6, and love it. I got the 2 antenna version but one antenna broke of in a crash and the Rx still works fine too about 800 meters, then you get throttle blipping. Good luck with your moth!
Abe
Frankschtaldt
So I learned something new today.
So, today I discovered that servos come with (at least) two different size plugs. 20161217_110324.jpg
This is the TGY-iA6 Rx that comes with the TGY-i6 Tx I bought along with the 1.7g servo's recommended by Nerdnic for his Manic Micro Tiger Moth.
Can anyone suggest a fix?
Can I buy/make an adaptor or can I just change the plugs on the servos?
Or do I need a new receiver? If so, can anyone recommend one that will work with these servo's AND my TGY-i6 Tx?
Thanks in advance!
CaptBill
I've just placed my order and this is the Rx that is coming with it: "FS-iA6 6 channel with no opitions for sensors if not modded (for FT minis but have to be modded for LiPo voltage)"
I have what I think is exactly the same radio. Works great, I fly poorly but its not the radios fault.
I see no reason to make any changes to the radio and expect it will serve my plane needs for a very long time. I dont think you have anything to worry about, actually considering this radioscprice and usefulness you might wantcto celebrate
Bill
Frankschtaldt
Thanks Bill, I'm glad to hear you're happy with yours and I'm sure I will be too.
With the help of the Hobby King support centre I've found a solution to my other problem.
This will add weight which is unfortunate but as best as I can tell there is no such thing as a AFHDS receiver with molex servo connectors which would be the ideal solution.
So I have to spend a little more money but I haven't wasted what I've already spent and I'm happy with that!
quorneng
Frankschtaldt
A word of warning!
Some of those super micro 1.7g servos are intended for 1s operation (4.8v max) and can fail on the normal 5V supplied by a BEC.
In addition I bet if you added the weight of the Molex to JR adaptor to the servo it will end up more than say a 3.7g servo that is intended for 5V operation and already has a JR type plug!
You would do better to use a 'micro' rx that uses Molex connectors.
mjmccarron
I find this really interesting. Years ago I built a Paragon glider. At 108" wingspan I wasn't worried about the light color scheme I picked for it. (Light blue, white, with a little orange and yellow) It was nearly invisible as it left the high start. It scared the begeebees out of me. As I get older, I find that certain colors are more visible to me. I may also depend on the sky too. A clear blue day vs hazy or grey. Very interesting indeed!
Mike
Frankschtaldt
Thank you so much Quorneng. You've just saved my blowing more of my limited money!
I think the best course of action for me now is to build the model and see what its weight ends up like.
If it's light enough I'll just buy a couple of 3.7g servos and use them.
Otherwise, I'm not sure what I'll do. I'll just have to cross that bridge if I get to it.
Frankschtaldt
A word of warning!
