Hi all,
In the process of building my first plane. Having issues getting my esc and motor to respond with my transmitter.
Im following the instructions of others and turning the transmitter on, opening the throttle to max and powering up the ESC, receiver and motor. Once connected to the battery via the ESC, the motor makes three ascending beeps, then continues to beep every second and turns slightly before bouncing back to its original position. It doesnt respond to any changes to the throttle and will continue to bounce back and forth. I'm also getting constant blue and green lights on the receiver (which as far as i can find means its a solid connection).
Ive checked all the solder connections and every thing seems fine. Ive also tried using a spare identical motor to no avail.
Any help would be much appreciated
