I have a Hitec X4 AC Pro...runs about $200 and can charge 4 batteries at once. It works good for up 4S batteries...haven't tried any 5S or 6S batteries on it yet. Even though I haven't tried it, I can tell from the numbers that it won't perform as good on 5S and 6S (maybe lower Mah it will). So if you plan on flying parkflyer size this charger or something similar should work great for you. If you do see yourself going with bigger planes and needing bigger batteries then you should consider a bigger charger. See here's an example using a 6S battery:
Battery: 6S, 5000Mah
Charger wattage needed: Watts=Volts x Amps ...so 25.2V for your pack (this is the total V for a fully charged 6S or basically 4.2V times the number of cells) times 5A will equal 126 total watts.
And if by some chance that 6S battery could possibly handle a 2C charge rate or 3C charge rate you would multiple that by the 126...so 252W for 2C or 378W for 3C. So in those cases you can see you'd need a higher wattage charger for a big battery. Even if a battery is capable of higher than a 1C charge I still would stick with a 1C charge (the 126W in this case).
So just some crazy numbers and math to think about for IF you want to start looking at 5S and 6S power. But IF you want to do park flyer size, I think a good 2-4 port 200W-300W charger should work fine.
And just so you know, the big issue with charging a larger battery on a small charger is basically time. It would basically take a lot longer to fully charge it (like we're talking hours).
