Possibly.
There are a lot more factors but in general the larger FT planes (Dusty, Spitfire, Mustang, etc) all run very well off a motor that is between 36-70g, 150-300w, and 1100-1400kv.
1100kv will allow for around a 10x4 or so prop and give you good thrust, this is important for feeling like you have good control over the plane, you'll be able to 'power out' of a potential crash.
1400kv works better with a 8x4 or 8x6 prop and will still provide plenty of thrust but give you higher top speed.
There are plenty of prop/motor combos that will work great, but if you let us know which plane you're looking to build we can suggest a proper fit.
