HELP! KK2 WILL NOT ARM WITH VERSACOPTER!
I have a versacopter with an orange receiver and a KK2.1.5 board with the remote programmer and it will not arm. ESCs are calibrated, it is bound, it lights up, does its beeps, but when on my DX6e I put the sticks on down and right to arm, it will not arm.
PS. all trims are centered + good
Thanks,
Wade
CrashRecovery
I'm a care bear...Really?
If I'm correct its just the rudder that controls the arming. Did you just try that? Also check your servo throw in the menu. You might not have it enough throw to arm the board. Also make sure the wires from the rx to the kk2 are plugged in the right way. You might be plugged in but the signal wire is in the wrong place.
#3
It could also not be level. Does the display show any errors?
Have you tried left and right? I believe only the rudder is needed to arm as well.
