GreaterAviation
So I built a "trainer" that has a 26'' wingspan that is powered by a 1300kv motor on a 3cell with a 7x5 prop. I threw it into the air and it pitched up hard so I added a bit of nose weight but now it glides for a few feet and then crashes itself into the ground.
Also my prop mount thingy is loose so I had to hot glue it on. How can I fix a loose prop mount?
Thank you for your help!!!
