Help resetting controller
Miner
Hi All,
I am new to this hobby and just built an ft freighter with my son. We were able to get the motors to synch and run for a few moments, but when we turned everything off to take our plane outside we couldn't get the motors to work. The lights blink on both the controller and the plane but never run steady and never get the motor running. Any help appreciated.
Thanks,
Josh
Pieliker96
Is the throttle all the way down? Some radio systems and ESCs won't enable motor output if the throttle is inadvertently left on upon startup.
Ifin that wasn't the issue, you can try calibrating the throttle range. This is typically done by turning on the transmitter, setting it to full throttle, powering on the plane, waiting for beep tones, then returning the throttle to the bottom of the range after which the normal startup tones should play (if they're there in the first place).
