Yes and no.
Flybarless has fewer parts, therefore less to repair and longer flight times since there's less drag through the air. They are also more quick to respond since you don't have to translate input through the flybar system. This time through the flybar is also what makes the flybar helis work in the first place. Flybar out of the box will be easier to fly. Flybarless will be twitchier unless to tame the settings in your radio. If you don't have a radio capable of that, then you will want to get a BeastX flybarless controller since you do all of the adjustments on the controller and not in the radio. I don't know off hand of any others that are that way. When you start looking at flybarless, your price goes up considerably. Look at the Blade 450 and Blade 450X. There's a few hundred dollar difference between them and the main difference is the cost of the flybarless controller.
Honestly.......for a first heli, I'd probably recommend a flybar. The setup is a bit more challenging since there are more parts to align, but once you learn it it's pretty fast to do. The heli will be slightly more tame out of the box and it will cheaper to get into. ?The parts are a bit more since there's more to buy in a crash but compared to the cost of the flybarless unit you can crash several times and be money ahead. Right now you can pick up the flybar blade 450 for 170 bucks and the 450X is still 500. If you look at the Blade 300X flybarless, it's way expensive too. It's all due to the electronics. Now, you can get much cheaper flybarless systems, but I can't speak to their quality. If you are interested I can point you to some discussions on that when you are ready.
Currently my only flybarless heli is my mCPx. My 400, all my micros and my Century Hawk nitro heli are all flybar. When I get ready to build my next heli it's definitely going to be flybarless but I'm ready for it. I can do flips and rolls and hover nose in, inverted etc. so I'll probably be more likely to really get the benefits.
A friend of mine that I usually fly and build with is along the same path. He started with a Blade mSR, Pheonix Sim, Blade Nano CP, then Blade 450 with flybar, now he picked up an Align T-rex 600 nitro that he's building up while he gets better on his 450. He had his first good crash last week where he lost orientation and planted it. He's got flybars in everything but his Nano. He went with the 450 flybar due to the cost of the heli after they dropped the price. He could get two for the price of the flybarless 450X. The heli is still more than he can really handle even with the flybar. Honestly, most pilots aren't probably good enough to realize the benefits of the flybarless system but they will notice the more rapid movements that make them feel "twitchy".
With all of that said, you can spend a lot of money and get a system that will rescue you with a flip of a switch. DJI has systems that will hold it in position for you until the battery dies or you run out of fuel. There are amazing systems out there but I think they're sort of cheating. You should learn to fly first before doing stuff like that. Those systems are great for photography or really super expensive models like giant turbine scale models etc. but for a play heli, it's sort of ridiculous to have a 2,000 dollar controller.
