help with battery options
So one more question. How do i fugure how much thrust my motor has? Do i need to figgure in my prop?
Usually motor have a prop data sheet or you can give a good guess based on motors of similar size and if you motor doesn't get too hot then its not too big. Usually branded motors have a thrust data sheet otherwise sometimes there are YouTube videos where people test the motor to see how much thrust it will make.
Shurik-1960
My other advice is to NEVER buy NO NAME motors, voltage regulators, or servomechanisms. Just throw the money in the trash, and when the desire to buy bad things passes, take the money out of the bank and buy the good ones.)))
I have bought some no name or brands I have never heard of before and they worked pretty good.....But it's a good idea to stick with name brands like Emax, Flash Hobby, RcinPower, iFlight ect.
jimlane06
another question . this time more on my desing of fuselage. will i have any advantage in having an airflow through my fuselage to keep my electronics cooler? it will increasse my drag a bit but is it worth it?
Yes it is definitely worth it, it save your electronics and battery in the long run. If you’re worried about drag, use NACA ducts.
