Thought I would go flying today, so I put my 450mah 3s to charge. The light still showed “charging” an hour later, which I thought was a bit much because I didn’t run the battery down to empty the last time I flew. I checked with a multimeter, two cells showed 3.85v each while one showed zero on the charging plug. However, I was still getting 7.7v on the power plug that goes to the esc, which doesn’t make sense because the 3 cells are in series-the series circuit would be broken if one cell is gone, so shouldn’t there be no voltage at the terminal? What’s going on? I’m a bit confused.
