UnleRIco
Hi guys, I am following this build: https://www.prusaprinters.org/how-to-build-a-3d-printed-micro-drone/
Build and soldering went fine. Binding was funny (the light on my FS-RX2A PRO V1 goes solid when my Tx turns on but no Rx bar shows up on the screen of my Fs-i6) Is that normal? I have seen at least one video on YT where the TX display had both a Tx and Rx bar on the top right of the display.
My FC connects to beta flight and I setup a serial receiver in the ports section but I can't get any connection between the Fs-i6 and the quad. (ie in betaflight on the receiver tab there is no movement.
In the configuration tab of betaflight I have DSHOT600 and I also have using a serial based receiver and SBUS.
I know that my FS-i6 works somewhat because I am able to connect it to my PC with a wire and use it with FPV Free Rider.
My receiver (FS-RX2A PRO V1) has 4 wires on a wire harness(black red yellow and light brown), but I could not find a pin out for it. Though on the page where I bought it, there is a question asked and supposedly the yellow wire is the ibus wire. If anyone had a pin out for this Receiver I would appreciate it.
Is there a way to verify communication between the FC and the receiver and also a way to verify communication between the transmitter and the receiver.
