help with motor mount on a tricopter
whalewill123
I've just gone on the tricopter webpage and under suggested motors it said 'Turnigy Park300 Brushless Outrunner 1380kv' but looking closer the mount is on one side and the shaft out other side with a prop saver but the package also comes with a prop adapter but I'm not sure if you can take the prop saver off and put the prop adaptor on or weather you have to reverse the whole motor and run it upside down. I don't want to have to buy any more stuff than I need. if you can help me then many thanks.
here's the website: http://www.hobbyking.com/hobbyking/store/uh_viewitem.asp?idproduct=14398&aff=247441
Carbon
Elemental Madness
The motor will mount under the tricopter plate and the shaft will go up through it to hold the prop.
