jimmyjames
hello all,
I have 2 Naze 32 boards V6, one brand new and one with heavy use. the issue im having is when i connect the board to clean flight everything works, i can flash software i can change PID's however as soon as i connect my lipo battery everything freezes. i am unable to calibrate my esc or set and transmitter settings because of this. i have tried new firmware old firmware, baseflight, cleanflight, betaflight all with same situation. and this happens on both boards.
both naze32 boards do this and i dont understand, im about to just through in the towel on the NAZE32 board all together, if anyone has any idea whats going on and knows how to fix it i would appreciate it to no end.
- hook board to USB with no battery everything connects and looks good.
- hook battery up and cleanflight baseflight betaflight freezes, and if you try and change tabs you just get waiting on data
- if you connect the battery and then try to connect to cleanflight it will not connect.
