Headbang
I know this is obvious and I assume you would have if it was possible. But the best way to solve this issue is have someone more experienced fly it.
Soldering that pulled out wire is a quick easy fix. There is just a small tab holding the metal contact in, you can lift the tab with a knife and pull out the contact. If you remove the contact you should be able to solder it to the loose wire and re-insert it.
