I've seen a couple of power-conversions around for this little foamy-chucker, but most had surface extensions and I didn't see any pure gliders. I don't have any spare mini-powered stuff lying around, and I'm mostly a glider-guy, so I took to converting it for the slope.
My goal was to keep it looking as close to it's "chuck form" as possible, which meant cutting in the surfaces and putting all the electronics in the nose. Luckily there's a ball bearing in the nose which weighed about the same as my micro electronics.
I used the following hardware:
Zippy 240mAh 1S lipo - x1
FrSky 5-channel micro Rx - x1
HK-5330 Ultra-Micro Digital Servo 1.9g - x3
Sorry there's not much detail on the build, I get impatient when building and tend to move faster than my brain can remember to take pictures.
It's pretty straightforward though.
Cut off the canopy - carefully - remove the ball bearing. Hog out the canopy to make room for everything.
Cut a spot for the servos and Rx.
Cut channels to let the pushrods out.
Mount control horns.
Cut control surfaces - hinge with packing tape of choice or FoamTac.
That's about it!
Haven't been out to the slope yet, but I did a park toss-test, so I wanted to share just the same.
The little dude came out pretty well, I think; only 2.7oz RTF. That puts the wing loading around 5.5 oz/sq-ft, which isn't too bad for a mini sloper! Between the micro-electronics and a bit of added tail weight from the pushrod and elevator hinging, I didn't have to add ANY ballast weight! (we'll see if that's still true on the slope)
Thanks for watching!
That's about it!
