I'm doing my first DYI build, based on the AnyCopter, and chose (based on everyone saying it's the board to use for your first build) the HK KK 2.1.5 flight controller. I've run into two minor issues (so far):
1) The fpvcentral review of the 2.1 board says " KK now supports plugging in a high-power LED right onto the board for easily-visible flight mode display". To me, that means showing me whether or not auto-leveling is on, however, I can't find any other mention or instructions for this. Do they just mean the LED will go on when you arm it? Or are they completely lost?
2) I've connected the voltage sensor, but it reads well over a volt higher than anything else I use to read the battery power. I was wondering if there was any way to adjust this, or do I just have to compensate when I set up the alarm value?
Thanks,
Mike
Thanks,
Mike
