HK RadJet 420
wassup guys im bout to order the HK Rad Jet 420 and was wondering if i could use it with my Fly Sky TH9x tx? From what i see on the review the Joshes did on flitetest the servos and esc connectors look to be a 1.25mm Molex 3 Pin Connectors, they also mentioned that hobby king has em for 9 bux but would i be able to bind that with my Fly Sky th9x(which is the same as the Turnigy 9x)? any help will be aprreciated thanks!
lobstermash
Propaganda machine
Hi, the rc they're talking about are the DSM2 compatible ones, which aren't compatible with FlySky. However they have adaptors that you can pull the plug off your rx (the 6 or 3 channel ones) and replace with the micro connectors. Or you can cut off the connectors and solder the wires directly on. Or you can replace the module with one of these: http://www.hobbyking.com/hobbyking/store/__17632__2_4Ghz_SuperMicro_Systems_JR_Module_.html. The receivers are pretty cheap for this series too.
#3
cool thanks alot Lobster, im prolly gonna just solder the servo and esc..thanks alot again!
