I had to mount my HK KK board on a foam mount consisting of 6 layers of double sided foam tape at each corner of the board to keep vibrations from causing the effect you describe. Hold your quad above your head FIRMLY and run up the motors while feeling for vibration at various throttle settings. Carefully check prop balance AND motor bell balance without the props if any vibration is detected.
Thurmond
Thurmond
