Thank you for your inputs to my question. I’ll build the Versa Wing for the time being. because the store in which I buy my electronics is closed for the holdidays untill the 20th. That means I got no MT1806 motor until then, but I do have a BL2210 which might be to heavy for the TT but could defentaly work on the Versa Wing.
As promised here is the way I create my plane plans so that they can be reused for a decent while, as well as easily stored. This is a somewhat long process but I feel that the plans can be reused and saved for a longer period of time without wearing out.
Based on Josh Bixler’s video “
Making Template Plans - Quick Tip | Flite Test”, I do these steps.
1) Print out the titled plans.
2) Cut off the printed pages on their bleed marks.
3) Tape the pages together to create the full sized plan.
4) Cut the full sized plan into the different plane pieces about half an inch from their outer black line.
5) Spary Super 77 on the back of the plane pieces and glue them to a 240 gram poster paper, while tying to get as many pieces as possible on one poster paper.
*** I’ll usually place them on the poster paper before using glue to get a visual of how to maximize the use of the poster paper.
6) Using siscors I now cut the poster paper into the different plane pieces, cutting as close to outer black line as possible.
This is where I stop following Josh’s “
Making Template Plans - Quick Tip | Flite Test” video and add a few extra steps some based on this video “
Painting Your Scratch Build | Flite Test”
7) Spary Super 77 on the back of the cut out pieces and glue them to cellophane wrapping paper or some other clear plastic wrapping paper. This is what I use.
8) Cut of the excess material to get the separate plane pieces with a plastic bottom on them. I usually just slide my siscors half way open around the edge of the pieces and that cuts of the excess without any fuss. This is what your looking to achieve.
9) Using a professional cutting knife mark score cut, creases, or anything else that you want to be able to mark down later onto the foam board. This is how one of my pieces look like.
10) Spary Super 77 on the back of the plane pieces (the side with the plastic wrapping paper). Don’t spary a lot, and let it dry for a good two hours. What we are trying to achieve is a sticky layer with no strength to actually glue down rather that just stick. After about two hours touch the pieces and feel how sticky they are if they are very sticky wait more. Don’t rush this step because there is nothing more annoying than having the piece glue to something where it can’t be removed.
11) Take another piece of cellophane paper and stick the plane pieces to it.
12) Cut the cellophane paper about half an inch from the edge of each plane piece and set aside.
13) Create a storage case to fit the plans. I usually use the cellophane wrapping paper to create a clear envelope like this one which also stores and plane pieces that I am working on.
That’s it we are done creating the re-useable plans. How do I use them? Simple.
I peal off the cellophane wrapping paper and stick the piece I want to foam board.
I use the plan to mark score cuts, creases or anything else onto the foam board. After that is done you can do two things.
1) Trace the piece outline to the foam board remove the piece template and cut out the piece.
2) Use the piece template to trace cut the piece out and the remove the template itself.
