HobbyKing Quadcopter Control Board V2.1
Arno1978
Hi everyone,
I am new to multi-rotor setups, and I was looking at the HobbyKing Quadcopter Control Board V2.1.
Except for plugging in all the wires in the right places and adjusting the gain on the channels is there any programming I have to do before I can get the Quad copter flying?
I am looking at getting the Hobbyking Super Mini Quadcopter Frame with Motors which was launched in December, but I need some assistance in getting to know what I should get.
My list so far :
Mini Quad Copter Kit
http://www.hobbyking.com/hobbyking/...Mini_Quadcopter_Frame_with_Motors_445mm_.html
10 AMP Esc
http://www.hobbyking.com/hobbyking/store/__6455__Hobbyking_SS_Series_8_10A_ESC.html
LiPo Battery 2 Cell
http://www.hobbyking.com/hobbyking/store/__9165__Turnigy_1300mAh_2S_20C_Lipo_Pack.html
Gold Connectors
http://www.hobbyking.com/hobbyking/store/__66__2mm_Gold_Connectors_10_pairs_20pc_.html
Quad Copter Control Board
http://www.hobbyking.com/hobbyking/...adcopter_Control_Board_V2_1_Atmega168PA_.html
Spektrum 6CH RX
http://www.hobbyking.com/hobbyking/...rum_DSM2_6Ch_2_4Ghz_Receiver_w_Sat_Port_.html
6 x 3 Props
http://www.hobbyking.com/hobbyking/store/__11317__6x3R_Propellers_Counter_Rotating_5Pcs_Bag_.html
Am I missing anything else?
Thanks for a great place to share this hobby.
Burg
Never catch a multirotor
Hi Arno,
The HK board v2.1 is a low entry, low cost board, perfect to begin with.
Pre-programmed in quadcopter plus-mode, plug and play.
The nice thing is that it is 'flashable' with other firmware, like tricopters.
So if you realy enoy multirotors, you can try other platforms as well.
http://www.rcexplorer.se/Educational/HKKK/HKKK.html
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=21321
Your shopping list is good.
Some remarks:
- Get also the standard rotating props (order many of both !)
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=11316
- Get loads of these (if you dont have them already):
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=8234
- Order this for connecting the battery to the 4 esc's:
http://www.hobbyking.com/hobbyking/store/__10254__XT60_Male_w_12AWG_Silicon_Wire_10cm_5pcs_bag_.html
Or just the connectors and make your own :
http://www.hobbyking.com/hobbyking/store/__10414__Male_XT60_connectors_5pcs_bag_GENUINE.html
Or get one of those power distribution boards (very easy).
- Get some sort of visual / accoustic battery alarm's.
I use these and work great !
When one of the led's becomes red, stay allert
When it stays red : replace battery
There are also versions with beepers.
http://www.hobbyking.com/hobbyking/store/__4175__HXT_Lipo_Monitor_3S_A_must_have_for_all_lipo_users_.html
- Get a good battery strap
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17411
or use velcro
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=9374
- Get these for connecting the Rx to the control board (or make your own)
http://www.hobbyking.com/hobbyking/store/__21758__10CM_Male_to_Male_Servo_Lead_JR_26AWG_10pcs_set_.html
- Get cable ties
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=17570
- Get another frame (without motors) for spare ...
- Make space in your house .. before you know it, it is stuffed with these things ;-)
ananas1301
Crazy flyer/crasher :D
If you want to be able to flash the board with another firmware you´ll need to get this:
http://www.hobbyking.com/hobbyking/...Programming_Device_for_ATMEL_proccessors.html
http://www.hobbyking.com/hobbyking/...e_to_Male_Servo_Lead_JR_26AWG_10pcs_set_.html
Those fore connecting the board to the RX
Then some rubber bands to attach the Props to the motors, which have an "onboard" Propsaver. The link the right ones is just below, when you go on your mini quad copter kit. It will say Spare rubber rings (10pcs) and these are the ones you´ll need to.
Maybe a programming card for the ESC´s
I think that this should be it.
Great: I was to slow.... Well done Burg, you´re awesome :D:D You got more anyway.
glydr
How many letters do we ge
Great thread. All the advice I was going to give is already there.
I've got one of these quads coming from HK at the moment (should be a few weeks yet). I'll be posting here my setup and thoughts.
Shadow74
Multi-rotor madman
Thanks that would really help as I mentioned this is my first time getting involved in quad copters etc.
you will love it. :) quads are great once you get them set-up. They fly very stable, and fly very predictable. I had miniature aircraft's rotor x 404 and had such a blast with it, that I made my own design and never looked back. truthfully since getting into multi-rotors i havent flown anything else since. my airplanes and my heli's are collecting dust.
good luck with your build, post pics :)
Eric
