Home Brew Thrust Vector !
Nitro Blast
Check out the home brew Thrust Vector setup
Recently, I came across the new Hyperion Enigma. A new 3D ship that has Thrust Vectoring. Check out my post with video: http://www.wattflyer.com/forums/showthread.php?t=60992
Well the Thrust Vector device is hidden by the cowl, but I went to bed dreaming about it... I woke early the next morning, and after 15 minutes with off the shelf parts, this is what I came up with...
The worlds first 2 Dog RC EPP Yak 54 with THRUST VECTORING!
attachment.php
attachment.php
Super cheap, I used landing gear nose blocks. Off the shelf less than $5.00 for a pair of packs. Simple attachment at the motor base, add a servo, mix it with rudder and PRESTO!
Brian fred carr
Site Moderator
nice job nitro blast.....did it work???
Nitro Blast
Oh yeah it works spectacularly!
I also did it to my AirfoilZ Edge, and it works better on that plane due to the fact it is lighter.
Frisbee style flat spins, and Pinwheel style vertical spins!
For the cheap $$, I say everyone ought to try it.
Here is the AirfoilZ mod:
Looks like the motor is shaking its head, "no! Don't put me up there again! All you do is thrash me around for your personal entertainment!" LOL :D
ananas1301
Crazy flyer/crasher :D
Yeah it is a great idea! I have been thinking about using the same mechanism you did there on my tricopter but I didn´t find anything looking close to that...
But it seems to be working quite well with you, so have some nice flights with it!
Nitro Blast
Boy I tell ya folks... if you havent done this yet you owe it to yourself to try it. SUPER FUN!
I can flat spin, and gain altitude... Knife edge flight can be done so crazy slow now it looks just wrong!
spitfire40
hi dear nitro blast ,
great idea , can you post some picture step by step that help , me clear view ,
want to make this vectoring thrust ,
do we need 3 pcs of landing block ?
how you fix servo arm fro motor movement ??
if just remove motor then i can see ,
hope you guide ,
thanks
Chuppster
hope you guide ,
thanks
Hello @spitfire40. We haven't seen Nitro Blast on the forum for over six years, so I doubt he'll get back to you. But I can help you with thrust vectoring if you're working on a project. What are you thinking of building?
spitfire40
well come back dear nitro blast, i have
Swift EPP 3D - TechOne Hobby
plane and want to convert this plane into vector thrust , it would be thankful if you send me picture of your plane without motor ,
so i can see how you fix servo arm , and what size landing block did you use ??
if you need my whats app no i can pass you .
guide me with left and right vector thrust what maneuver we can do ?
did you try up and down vector thrust ?
thanks again for your kind reply
Chuppster
You've got a lot of options! Be creative, I'm sure you can work something out, and I can certainly help if you have any questions! Nitro Blast used some hinges to give is motor mount the ability to swivel, then he placed a servo behind the motor and did a direct linkage between the servo and the motor mount. You could try something similar!
