EraJomppa
RC Enthusiast
I got myself a rare free weekend and even though I have couple of other RC projects in progress, I decided to make myself a bush-type plane from some spare parts I had laying around.
Here is the result:
Specs for those that are interested:
Weight: 300 grams
span: 900 mm
length: 700 mm (front of the prop to tail)
Rudder, elevator, ailerons and flaps. Flaps are bot behind one servo. Ailerons are separate channels so I can try to add differential or airbrakes (flaps + spoilerons).
Powersetup:
1100kv 25 gram outrunner (old motor, forgot brand...)
3s 500mAh LiPo
5x 9 gram servos (various brands)
10" prop
(cut down 11" prop, Im going to buy 9" and 10" props to try which is the best)
FrSky 7ch Rx
I need to glue some 3mm depron to the top of the frame so it wont be see-through, also I still need to buy BIGGER tires! these are way too little for a "bush" plane
I did fly a maiden, but its was way too windy to say anything about the characteristics really. It flies, can maneuver in the air and flies quite slow. I just kinda eyeballed the CG and it turned out pretty well, I'm waiting for a calm weather to properly adjust it.
The landing gear got torn off on the last landing on the maiden, and I ran out of hot glue so I cant put it back on
Well I would not be able to fly it anyway with the wind so I guess it doesn't matter.
Here is the result:
Weight: 300 grams
span: 900 mm
Powersetup:
3s 500mAh LiPo
10" prop
FrSky 7ch Rx
