Hot Iron Trailing Edge and Folded Airfoil Experiment With 6mm Foam
Wildthing
Well it was yesterday, a quick couple tests for the new (Iron Maiden ) Baron , maiden flight and a second one with a little adjustment to the rates. I didn't know what to expect compared to the spec or normal Baron so I backed everything off. Pitch ended up at the same rate and for roll I went up 10% . Seems to fly good and it has speed, for speed I think it is comparable to the smooth Baron wing and it is 20 to 30% faster then the standard foam wing. Everything stayed together so that's even better :D
