laramie187
I built an alpha...I put in a 2205 2300kv ft motor, ft 20amp esc, and a 4s 850mah battery....the motor gets so hot after a few seconds of flight...meaning it will burn you if you touch it...then tried the 1806 2280 with same esc and a 3s 850mah battery....and it also got extremely hot after a few seconds...yes I have the pusher prop on.......which way is the motor suppose to turn...ccw or cw...I thought cause of the pusher prop it would go clockwise...even if I had rotation wrong and prop on backwards I wouldn't think it would get this hot....it actually will shut down it gets so hot
My goal is to make this thing extremely fast...so if you have a recommended motor that would be great too
