badpilot27
I saw some of the cool foam board prantdtl wings that @FoamyDM made an saw one that flew really well with little sweep and taper
I was thinking about making it out of foam board but the process to get the wing twist is a bit too much for me so ive decided to make one with my hot wire cutter as my first build using it.
a little bit of cfd i did
it has a wing span of 1m with the root airfoil being a naca 4412 with 8 degrees of twist and the tip airfoil being a naca 0012 with -2 degrees of twist.
at the moment i have the the the templates screwed into the foam block for the left wing and hopefully I can get the whole wing cut out tomorrow.
