so here are a few quick an easies that i figured i would tackle in my boredom today since they where posted in the thread as would be covered.
- Flap
flaps are extensions on the trailing edge of a plane's wing as they extend they do a couple of things. they add length to the top of a wing and that increases the low pressure zone above the wing. it adds drag to the bottom of the wing, and this does 2 things, it slows down the air underneath creating a larger high pressure zone, and that drag slows the airplane. this basically lets an airplane fly at speeds lower than stall speed and it will slow an aircraft down as needed. a plane will generally land with full flaps which allows the slowest landing speed possible. and a plane will take off with some flap. not enough flap to create tons of drag, but enough to create lift and take off faster.
- Stall
a stall is really simple, as formerly explained, lift is the force that keeps an airplane in the air and "lifts" the plane straight up. generally, the faster a plane flies, the more lift is attained. lift is opposite weight. drop something heavy and wingless (an apple) and you understand what weight does to an object without lift.
understanding this; a stall is what happens when a plane slows down so much that the lift created cannot compete with the weight of the plane. and the plane drops. when this happens it is best to nose down slightly, and increase throttle. this will add airspeed to your plane and lift and will generally counter your stall. unless your plane has spun.
- Spin (not on the list but while we are talking stall)
a spin is where one wing becomes more stalled than the other wing, this makes the airplane not only drop, but to spin in the direction of the stalled wing.
note that NOT all airplanes are recoverable in a stall. some planes just can't do it, and some are too close to the ground.
once you spin there may be a few different ways to recover. but this is the way my flight instructor told me to do it
acronym PRAY
P: Power off, don't shut down, but idle the motor
R: Rudder opposite, if your spinning left, yaw HARD right. spin right, yaw left.
A: ailerons neutral, just the way it sounds, center the stick.
Y: Yoke neutral, meaning your elevator. center the stick.
PRAY your high enough to recover
PRAY your aircraft is recoverable
PRAY you don't spin (unless you want to and your good enough to)
PRAY God likes you, cus when you hit the ground, the next thing you see will count on it.
by PRAYing you will drop your nose, increase airspeed, and counter the yaw of the spin. and hopefully be able to return to level and controlled flight
- Ascend rate / Descend rate
basically exactly the way it sounds. it is the rate at which an aircraft is climbing or descending. by ascending you gain altitude. by descending you lose altitude. normally measured in feet gained/lost : feet travelled.
your airplane is climbing and for every 20 feet it flies foreword it gains 3 feet. glide rate is +3:20 or if it descends at these same rates, drops 3 feet every 20 feet its rate is -3:20
just a couple of ideas explained to expand the topic.
