How can i start making my planes fly
Enzo2
So the past year i started making planes but only one of 10 flew i tried so many models but none of them fly or im so ass to fly them.
Is there any warbird easy to fly and nice looking one with free download?
Dutch Breeze
The FT corsair is a good one. How was the CG (center of gravity) on the other 9 planes? and don't feel too bad, you may not be a great pilot at the moment, but you'll become a better modeler everyday! Build, Fly (however brief), Crash (however epic), Repeat. Its the life of a Pirate Pilot First Class. It's not for everyone, but it is for me. Welcome aboard matty!
...Is there any warbird easy to fly...
No, warbirds are not easy to fly, they are built for maneuverabilaty. You will be better off learning to fly with a trainer, they are built for stability. When you learn to fly, then build the plane of your dreams.
First learn to crawl, then walk, then run.
The Tiny Trainer is an exclent first plane.
Shurik-1960
98% of all aircraft modelers in Russia and the Baltic states flew thanks to this model. I also learned how to fly a Cessna 150. On this model, we staged aerial battles, mowed the grass with propellers in low-level flight.I have a Cessna 150 with 4 models made according to different drawings.
Enzo2
I have been flying a trainer but i cant make the transition to the warbirds
Enzo2
Make the trainer more twitchy one change at a time. Like move the CG towards the tail a teensy bit, bigger control surfaces scabbed on, bigger motors/prop combo.... eventually you get to the point where a warbird is tame compaired to the changes you made to the trainer then the transition is easy.
I agree with @Piotrsko.
Start by increasing the throws on the control surfaces 5 degrees or so and move the CG aft 1/4 inch. You will be flying a completly different plane. When you have mastered 1 round, try a bit more. After mastering the 2nd round try flying inverted. When you can fly inverted across the field, you will be ready for a warbird or any other plane you want to fly.
Enzo2
The cg on the other aircraft was a bit nose heavy and one tail heavy that was the first but after a lot of trying i cant get the plane up or just to turn i loose control my rc radio cant make so much becouse it is a cheap one 5 ch
Sounds exactly like my beginning story, If you really want a warbird, build the FT Swappable Mustang, it was the first plane I was able to get to work, very forgiving, just build light. And balance it a tad nose heavy compared to the plans.
Enzo2
I will try to make! one question its better the mighty mini one or the full size one?
Dutch Breeze
I see. that does present a problem. Have you range checked your radio and receiver? If not remove the prop for safety, turn everything on, set the plane on the ground and walk a good distance away and activate your control surfaces. have a friend watch them for you if you cant clearly see them. if you see studders or unintended movements you may have some interference issues. thats just a technical place to start. good luck and keep going! it is soooooo worth it!
