Hello!
A friend and I set up a tricopter following the project posted by you and we have a big problem. http://flitetest.com/articles/tricopter-scratch-build
Every time we try to calibrate the ESCs kk2 board by following the instruction manual of the ESC happens the following error:
With the throttle lever all the way up we heard the beep setting and put the lever down. The ESC's another beep and that's where comes the problem: When we increase the trhottle engines do not rotate. The kk2 board is receiving the signal, but the engines do not rotate. We need this adjustment because the engines do not start simultaneously.
