4U2NVME
Hey everybody,
Finally gotten a chance to get back to flying, been a busy spring and summer. I built the FT Cub and had some issues with the ESC. So I changed it out to an eMAX BLHeli 30A LiPo 2s - 4s ESC.
The issues I had with my ESC went away when I changed it...or at least for a while. My last flight I hand launched the plane, and the prop sounded a bit weird so I brought it in for a landing and made sure my prop was on strait ( I use a prop saver ) It seemed to be so I tried to launch it, and the prop did not really start up, it chattered a bit as if it was having a hard time starting, then all of a sudden magic smoke came out. I thought my battery was on fire so was not sure what to do right away, I did flip the plane over and saw the LiPO was not on fire so I unplugged it from the ESC
I did the throttle reset when I added the new ESC.. This is my third ESC that has crapped out on me in one way or another... this was just the fastest and most spectacular
I did check the battery right away with my battery checker and all 3 cells were within a very small amount of volts of each other, and it was still over 90%. I am using my original motor that seems to be working correctly...
What I am using:
BLHeli 30A ESP LiPo 2 - 4 S
Venom Drone battery 1350 mAh 30 C Lipo battery
9 * 4.7 slow fly prop
A 2212 / 10T 1400 KV electric motor
I have attached some pictures of the carnage, I am not sure what I did wrong, any help be appreciated.
-NV
What I am using:
-NV
