Hi guys, I've been trying to figure out how low I make the Voltage supply to a '12V' ccd camera (Sony 1/3" board). I've hooked it up to a charged 2s Lipo and it works great. No loss of image quality at all. For the Hobbyking listing it says 9-12.6V, but that's clearly not accurate.
The reason I ask is that I have set up a new camera that's intended for a parkflying short range FPV setup. It'd be so much easier to plug the fpv rig into the balance plug than rig a Y cable up for the connector. I'm going to try and get away with not using an lc filter. If it's too bad, I'll use a seperate, small (350mAh) 2s battery for the fpv gear.
