How to build 20cm high 40cm wide tricycle main landing gear within 50g
YTF
How to build 20cm high 40cm wide tricycle main landing gear within 50g? thankss the propeller is 18in. large and weight requirement for my rc plane design is tight so it is tricky
#2
Do you need it to be steerable? If so it could be very tricky, if not, then look at how flitetest does landing gear (storch, edge or simple scout build video would be a good place to start) and bend some out of 0.1 music wire.
YTF
Just as main landing gear, my plane weighs about 2.4kg or 5 lb
Thz for the tip!
