This may be a stupid question, but...
In the instructions, it mentions the square "reflector" on the bottom...
Although I see "copper sheet" mentioned in the Parts List, the only material for the Reflector I see used in the instructions is the Fiberglass PC Board.
Then later on, we're soldering the "4 pins" to something on the Reflector, but it never told us to use anything but the 50mm x 50mm Fiberglass PC Board.
If it's a "Reflector", shouldn't there be something metallic attached to the Reflector Assembly? Not just a non-conductive Fiberglass PC Board?
(I'm guessing a 50mm x 50mm piece of the Copper Sheet is attached to the 50mm x 50mm PC Board... am I right??)
Thanks,
--Johnnie
