How to build a 5.8GHz Helical Antenna
Hi Gang
I have been working on instructions on how to build a 5.8GHz Helical Antenna.
Enjoy
DM :)
  • Helical Antenna.pdf
  • Guides.pdf
zann68
Finally!!
Finally someone made this in an easy format to follow!! I have looked at making one of these and gave up. No problem on a 900mhz or a 2.4ghz coil instructions. Going to make one today now!! Thanks
Hi zann68
The above instructions are appropriate for 5.8GHz only. You will need to scale them for 900MHz or 2.4GHz. My intention was to collate everything I'd read into a simple guide. I hope they point you in the right direction.
Kind Regards
DM
zann68
Hi zann68
Kind Regards
DM
It does. You cannot find a good instruction for the 5.8ghz helical's. I've ordered my boards & plugs to make one for myself and my son. Do have a question though. The Guide is it to scale? Not much worried on the reflector but the pattern for the dowel wrap.
Thanks again for you efforts for our hobby!!
Hi zann68
Thanks for the kind words. Everything is to scale. When you print the guide measure the width of the forma, it should be 47.1mm wide.
Regards
DM
zann68
Direction
Hey, this being my first Helical Antenna I need to know does it matter on the coil direction. I know when I make the CL you have a Right Hand and a Left Hand. Does this apply with these as well. Just wondering:confused:
Thanks in Advance
Hi zan68
The Helical Antenna is circularly polarized, so you can make it either left hand circularly polarized (LHCP) or right hand circularly polarized (RHCP). The article that I have published is for a right hand circular polarized (RHCP) antenna. I find the easiest way to think of it is to imagine a bolt and its thread (see below).
Hope this helps
Regards
DM
zann68
My Build
Thanks in Advance
Thanks for your step by step build on the 5.8ghz antenna. Took me about 20min to make this one. The only thing I did different was hot glue the base where the coil meets the sma plug for better support. I also hot glued a small dowel to the coils as well for support. Radio Shack had every thing for this build. Cost was around $14.00 half was that sma plug :)
Hi zann68
Nice work. As a suggestion, I would probably not hot glue the base of the coil where it meets the SMA connector however the dowel support is fine. Let me know how it goes.
colorex
Unfortunately, it is very expensive to purchase electronic parts from retailers here in Australia. The last SMA connector I purchased was almost $10!
Regards
DM
colorex
Rotor Riot!
colorex
I can buy 3 bananas here for $0.05! But if I want an RC plane, it will cost me about $350 for a SuperCub RTF. Electronics stuff isn't that bad, I don't know about that SMA connector, but similar cable TV connectors are out there for a dollar.
Tritium
Amateur Extra Class K5TWM
SMA connectors run $3.25 ea from Jameco Electronics in the US. colorex that looks like a cable TV type connector. SMA connectors are the type on the antenna connection of most wireless routers. Dead routers are a great source to "scrounge" them from for free.
Thurmond
bmsweb
100% correct! Maybe our SMA connectors are made of Gold lol
