Once you move into large EDF's jets, these are suggestions that I use to stay at the flying field all day.
When my car needed a new battery, I installed the heaviest duty battery(amp hours) that would fit in the car dimensions.
For jets, I use anywhere from 3s to 4s cells and from 2200mah to 4400 mah with 70 C for a 3-5 min flight. So you need a DC/AC charging unit to use to stay all day.
So I start a rotation bringing planes that use 1300mah to 2200mah and alternate charging the big ones. I keep track of the voltage of the car battery and when needed, start the car and charge up.
My charger lets you input the value that stops the lipo charger so you don't drain the car battery. Other neat thing my charger does is only puts 95 % charge, so that you will get a longer life out your lipo battery, especially the big C batteries.
