Use Velcro strap, you will get eh shape even and correctly, you are applying too much weight which will cause foam warp and the objects and layout you are using from picture will even cause your issue, simple system I use, I pretty much stopped using hot glue and when I do it is to tact something down, I use foaming and non foaming glue.
