cloudseeder
I’ve held the UMX Ultrix as flat as feasibly possible when connecting power on the field. Upon hand-launch, the trajectory favors the ground. Constant elevator deflection required, and i’m new to 4-channel (experiences in powered glider w/o aileron only). I managed, although broke a prop on my first 10 seconds of SAFE mode deactivated. After quick repair, managed to fly with some acrobatics (rolls and spins; no flat spin but variants of the ‘blender’ basically), and land safely.
The problem is that the plane, on SAFE mode, wants to nose-down. I’m holding it as flat as I reasonably can when connecting battery. How to deal with this? I think trimming would be overridden by SAFE mode gyroscope ‘impression’ of level flight... What do you all do to avoid this? Is it my CG? Or, not “level”-enough when I connect battery..?
I can fly it, even with SAFE off (although winds inevitably force me to use SAFE to recover), but i’d prefer if my SAFE switch correctly understood “level” flight...
