I've got a trifecta frame with APM 3.2.1 and digital tail servo.
As soon as you throttle it up a little the tail starts wobbling left and right really violently. It becomes totally uncontrollable in the air. I've experimented with various PID values to no effect. The most I could achieve is to make the tail stiff which is no solution either
Interesting thing I noticed today is this only happens with the RC7_REV parameter is set to -1 (default is 1). This is done as per the APM instructions and is made so when the yaw stick is left, the tail turns right as it should be.
With the default setting of 1 the tail turns left when the yaw stick is left.
I immediatelly reversed the yaw channel on the radio thinking I've found a solution, well it doesn't wobble but just rotates around itself rapidly.
So after days of experimenting and second APM board, I can't find a way to make APM works with a tri. Which is odd because i've seen plenty of videos of this combination.
At this point looking for advice what else I could try. uh
