Is this the type of airfoil all ft planes use?
No. They use a number of different wing builds. Some "Flat Plate" Some "Bent Plate" but most are a multi-bend and fold to an airfoil. Below are some examples.
A Flat plate wing is usually a single piece of Foam board that is Flat. The F22 is this type.
A Bent Plate is a single or so bend that has no bottom plate under the wing. The Mini Scout has a single bend in to a slight V.
An Airfoil wing has a varying number of bends, usually on top and a plate or bent piece under the wing. The Mini Tutor is this style.
The KFm (Kline-Fogelman) wing has a primary Flat plate with any number of other flat plates added top or bottom to form an easy to build airfoil. This is denoted by KFm then a number. There is a chart to show how these are designated. See below.
I am sure someone has more scientific names for these types of "Airfoils"
