I've been trying to build an FT Versa wing, but I have found it really hard to get the two wing halves to come out the same. I've tried a few times, and I'm getting rather tired of it not working out again and again.
So where do you tape the sheets of paper together? Right on the edge? Where the little dashed line is? I assume that it's the dashed line, but the problem with that is I can't see the dotted line on the sheet that is under the one I'm taping, making it difficult to line it up to say the least. Why don't the plans do all the way to the edge of the page? It seems like that would make it a LOT easier to put it together since you don't have to try and guess where the dashed line is.
I tried using a fish tank with a light inside shining up through the paper in hopes that it would make it so that I could see the lines, but it didn't work that well.
If anyone has any ideas, it would be really appreciated.
