randyrls
Randy
I did the classic THREE LOOPS and fold the wing. I was able to return to the field and land successfully. No damage to the plane. Wing just has crushed foam at the wing joint. I had already used fiber tape for the center joint.
So how to reinforce wing center??
A. Cut open top of wing and insert plywood spar with dihederal angle cut into spar.
B. Use 1/8" (3mm) or 1/4" (6mm) plywood?
C. Make even with top of wing or embed into wing?
Any info on how to make a strong wing appreciated.
