Help! How to remove prop adapter (I think that's what it's called)
Harry Joelsson
These new props came with the plastic ring stuck inside it, the same ones that come as a pack with the props. In order to get it fit to my motor I need to get it out, how? It's stuck pretty good.
The red neck way would be to just push it against the motor. Or you could try a hobby file (the ones with the hooked end) or small needle-nose pliers.
bisco
put it over a vice with the jaws just a bit wider than the ring, and tap the ring with a cylinder just a bit smaller
