How to replace DT750 DT700 DT850 bearings
tecdux
Hi guys!
I was getting lots of vibrations from my Hextronik DT750 even after balancing it and using balanced props. I replaced the bearings and now the motors are like new!
The steps for DT700 and DT850 are similar
I've done a video showing me disassembling the DT750, changing bearings and then reassembling it:
http://www.youtube.com/watch?v=LcasyjsCLyw&hd=1
Hope it helps :)
Cheers!
tecdux
#5
Internal diameter: 4
External diameter: 8
Height: 3
4x4x8 may work since is just 1mm taller, but I've already replace with 4x8x3 and it fitted perfectly ;)
colorex
Rotor Riot!
Height: 3
Aha I see :D
Will totally consider this for my quad! I assume the motors run more silently with better quality bearings?
tecdux
#7
Actually I was getting a strong vibration after a specific RPM, even after balancing the motor and props.
Just had to replace the bearings and the problem was solved! They now run more silently and with less friction :)
